Question Would it be possible to make Kunena use a different template
10 years 6 months ago #174800 by HardstylerDK
When visiting the frontpage of my site, it uses a template called SJ Tech News.
My question is, would it be possible to use a different template than SJ Tech News, for Kunena, when users click on, lets say, the Kunena menu item called "Index"?
10 years 6 months ago #174802 by sozzled
If you mean, "would it be possible to assign a different Joomla template depending on the forum view", then yes, it's possible. See Moving Kunena forum component position
If you mean, "can you use a different Kunena template (say, Crypsis or something else) depending on the menu item selected", then no, that's not possible.
Does that help?
10 years 6 months ago #174812 by HardstylerDK
Lets say that I've got two Joomla templates installed on my website.
Template1, i would like to use for the frontpage, but when entering the Kunena forum, i would like to use Template2.
10 years 6 months ago #174813 by rich
You need this selection at all menu items which linked to the forum.
