Solved All emoticons displaying!
10 years 6 months ago - 10 years 5 months ago #174564 by jplamp
I just upgraded Kunena from 2.0 to 4.0 on a Joomla 2.5 site. We are planning to upgrade Joomla to 3.4 after we get all the bugs worked out in the upgraded components.
Our site has over 200 emoticons. In Kunena 2.0, I had found a fix here in this forum so that only the basic emoticons showed when creating a post, with a button to expand it and show all of them. Now, in Kunena 4.0, when I create a new post, all 200 emoticons are showing, and I have to scroll down quite a ways to get to the text box to write my post.
Is there any way to hide most of the emoticons and only show them when a user clicks a "more" button? Or can they be made to scroll, rather than showing all of them at once?
Thanks in advance for any help.
Here is my configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 800M | Max file upload: 300M
Joomla default template details : siteground-j16-47 | author: SiteGround | version: 2.5/3.0 | creationdate: 5 Jun 2012
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: CommunityBuilder 2.0.14 | UddeIM 3.2
Plugins: Search - Kunena Search 3.1.2 | Content - Kunena Discuss 2.0.4
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Login 3.1.2 | Kunena Search 3.1.2
Kunena 4.0.11, Joomla 3.5.1, CB 2.0.14, DOCman 2.1.5, uddeIM 3.8
Last edit: 10 years 5 months ago by jplamp.
10 years 6 months ago #174610 by rich
Replied by rich on topic All emoticons displaying!
Go in backend to "Kunena -> Templates -> mark Blue Eagle -> Edit CSS -> custom.css -> Edit CSS" and try this code: Then you should have a smiley scrollbar. Change the height as required.
div#smilie { height:70px; overflow:auto; width:100%; }
10 years 6 months ago #174642 by jplamp
Replied by jplamp on topic All emoticons displaying!
Thank you very much! I'll be able to do that after we do the Joomla upgrade.
Time to create page: 0.155 seconds
