Question Possible Attack on Kunena Forum
10 years 7 months ago #174554 by Graschki
Yesterday my hosted Virtual Server had a very high cpu load. I was very proud of myself to find the issue - I am a real Linux noob:
From varius Russian IPs came requests to
www.mydomain.de/forum/1-My-Kunenyforum-Name/administrator
which made on my server about 10 php5-cgi processes with heavy CPU load.
To solve the problem fast, I made a 301 Redirect on this URL to a Domain I don't use, and immediately the load was gone.
Is this a random test of a script kiddie or a possible attack on the Kunena Software?
10 years 7 months ago #174570 by xillibit
There are robots which scan all the web to check vulnerabilities or tries if some URL exists.
10 years 7 months ago #174573 by Graschki
Yes, I believe that this were bots, too. But the strange thing is, that these requests were causing really heavy load. I had PHP processes running 1-2 minutes with 10-20% CPU, and 100 or more at the same time. I guess that somehow the Kunena Script was running longer than usual.
In the error log was:
[Mon Apr 25 23:57:28.771140 2016] [fcgid:warn] [pid 10130] [client 123.123.123.123:52069] mod_fcgid: stderr: PHP Warning: simplexml_load_file(): I/O warning : failed to load external entity "/var/www/vhosts/mydomain.de/httpdocs/components/com_kunena/template/default/template.xml" in /var/www/vhosts/mydomain.de/httpdocs/libraries/kunena/template/template.php on line 142
(I changed IP and my domain)
10 years 7 months ago #174575 by xillibit
On a webrowser if you try to access the template.xml from your Kunena template, are-you able to see it ?
10 years 7 months ago #174578 by Graschki
indeed, this file - well the whole directory /default is missing. On the server and of course with the browser. But I am also missing it in the latest install.zip in the Download...
What should be in that directory?
10 years 7 months ago #174585 by xillibit
Before the version 4.0.x of Kunena the template by default was on directory : /components/com_kunena/template/default/
Maybe you can prevent the access to xml files from all our joomla directory in the htaccess
