Question Possible Attack on Kunena Forum
From varius Russian IPs came requests to
www.mydomain.de/forum/1-My-Kunenyforum-Name/administrator
which made on my server about 10 php5-cgi processes with heavy CPU load.
To solve the problem fast, I made a 301 Redirect on this URL to a Domain I don't use, and immediately the load was gone.
Is this a random test of a script kiddie or a possible attack on the Kunena Software?
There are robots which scan all the web to check vulnerabilities or tries if some URL exists.
In the error log was:
[Mon Apr 25 23:57:28.771140 2016] [fcgid:warn] [pid 10130] [client 123.123.123.123:52069] mod_fcgid: stderr: PHP Warning: simplexml_load_file(): I/O warning : failed to load external entity "/var/www/vhosts/mydomain.de/httpdocs/components/com_kunena/template/default/template.xml" in /var/www/vhosts/mydomain.de/httpdocs/libraries/kunena/template/template.php on line 142
(I changed IP and my domain)
What should be in that directory?
Maybe you can prevent the access to xml files from all our joomla directory in the htaccess
