Solved configuration
10 years 7 months ago #174116 by Simpelman
configuration was created by Simpelman
After setup I have two small problems.
1/ Users profile shows only 5 recent messages fraom that specific user
2/ Once logged in the menu/tab latest posts shows 0 posts
logged out a list of posts are shown.
10 years 7 months ago #174120 by rich
Replied by rich on topic configuration
Click on link "More" and select the time period "All".
You mean the menu item Recent Posts? This menu item shows your own posts when you are logged in. If you want show all recent posts (also from other users), go to "Menus -> Kunena Menu -> (menu item) Recent Posts". Add a star * in the field User ID and save it.
10 years 7 months ago - 10 years 7 months ago #174135 by Simpelman
Replied by Simpelman on topic configuration
Thank you for your answer.
Unfortunely.....
1 The link more shows 0 messages, since it gives the same result as the menu item recent posts
I want all posts from that specific user under his profile.
It had been like that.
2 There is no visible field thats called user ID (in my language)
Last edit: 10 years 7 months ago by Simpelman.
10 years 7 months ago #174137 by rich
1. Click on link "More" and select the time period "All" in the dropdown menu. This shows all messages from this user.
2. No matter which language. This option is available in the menu item Recent Posts.
10 years 7 months ago - 10 years 7 months ago #174144 by Simpelman
Thanks for your respond.
1/ me stupid! I added the star now.
No positive result, without login all last posts available
After login none
2 See the added photo's
On the he first image the link is "lees meer"
The second is the result, there does not appear a drop down menu
10 years 7 months ago #174148 by 810
Replied by 810 on topic configuration
change the filter "sinds laatste" to "Alle berichten" on the right
