Solved configuration
1/ Users profile shows only 5 recent messages fraom that specific user
2/ Once logged in the menu/tab latest posts shows 0 posts
logged out a list of posts are shown.
- Thank you received: 2545
Click on link "More" and select the time period "All".1/ Users profile shows only 5 recent messages fraom that specific user
You mean the menu item Recent Posts? This menu item shows your own posts when you are logged in. If you want show all recent posts (also from other users), go to "Menus -> Kunena Menu -> (menu item) Recent Posts". Add a star * in the field User ID and save it.2/ Once logged in the menu/tab latest posts shows 0 posts
Unfortunely.....
1 The link more shows 0 messages, since it gives the same result as the menu item recent posts
I want all posts from that specific user under his profile.
It had been like that.
2 There is no visible field thats called user ID (in my language)
2. No matter which language. This option is available in the menu item Recent Posts.
1/ me stupid! I added the star now.
No positive result, without login all last posts available
After login none
2 See the added photo's
On the he first image the link is "lees meer"
The second is the result, there does not appear a drop down menu
