Solved Recaptcha 2.0 ?
- CrasHofCinneT
then you need to add the 2 keys on the recaptcha plugin, on the joomla plugin manager
Kunena Blue Eagle template (and all 3rd party templates derived from Blue Eagle) does not allow you to use reCAPTCHA v 2.0. You can only use reCAPTCHA v 2.0 with the Kunena Crypsis template.
- CrasHofCinneT
You are using the blue eagle template in this case you don't need to enable recaptcha joomla plugin.
If you want to use Crypsis you need to enable recaptcha joomla plugin but you need to let empty the following fields in Kunena configuration settings : "reCAPTCHA Public key" and "reCAPTCHA Private key"
