Solved New registrated users can't write messages!!
10 years 7 months ago #173986 by spsurfer
we're using Kunena 4 for this page
armasblancas.es/index.php/foro-de-armas-blancas
recently, new registered users are not able to write new messages or answer.
Don't know what's wrong,
I tried to deactivate the "show online" option in the user details, but changed again to the original documents.
Any idea?
Thanks in advance
10 years 7 months ago #173987 by rich
What exactly is the issue? There is no error message?
Please create a configuration report .
The following user(s) said Thank You: spsurfer
10 years 7 months ago #173996 by spsurfer
Here the config
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : jsn_megazine_pro | author: JoomlaShine.com | version: 1.0.6 | creationdate: 01/15/2016
Kunena default template details : RND Kamethyst | author: Roundtheme | version: 2.1.0 | creationdate: 2014-07-25
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: UddeIM 3.8
Plugins: None
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Search 3.1.2
If a new registered user tries to post a message (new topic or answer) clicking on "send" he will stay on the same page, no message will be posted.
Now I'll upload again the latest back up to the server, hopefully it will help.
Regards
surfer
10 years 7 months ago #174001 by spsurfer
Ok, I think it's solved!
I deactivated captcha and now I can post!
But it's strange as we use the captcha since about a month and only recent registered users are affected.
Any idea? I would like to use the captcha again.
Regards
surfer
10 years 7 months ago #174006 by 810
maybe your kunena template doesn't work with v2 version of recaptcha
10 years 7 months ago #174009 by xillibit
Do-you have checked if there is an update for your Kunena template ?
