Solved Erratically logged in as another user
10 years 8 months ago - 10 years 8 months ago #173715 by clippy3
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : rt_paradigm | author: RocketTheme, LLC | version: 1.4 | creationdate: February 21, 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.10 | creationdate: 2016-02-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: UddeIM 3.8
Third-party SEF components: sh404sef 4.4.1.1762
Plugins: Search - Kunena Search 3.1.2 | Content - Kunena Discuss 3.1.2
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Login 3.1.2
Last edit: 10 years 8 months ago by clippy3.
10 years 8 months ago #173716 by clippy3
Has anyone come across an issue whereby the are using Kunena and they realize they posted as another user without logging in as that user? But that user is online.
I have had this issue for sometime, erratically. Initially I thought it was JCH optimizer so I removed it. Now I am wondering if it because I am using cloud flare. I am also using Siteground's joomla caching plugin.
Has anyone had a similar issue?
10 years 7 months ago - 10 years 7 months ago #174157 by clippy3
I added rule to cloud flare to exempt Kunena from cloud flare caching but still have same problem erratically. Have also disabled joomla caching. I can only assume its sitegrounds caching now.
Last edit: 10 years 7 months ago by clippy3.
10 years 7 months ago #174169 by xillibit
Do-you have tried to disable temporarly the sh404sef to check if it works better without it ?
10 years 7 months ago #174299 by clippy3
Hi Xillibit,
have now removed 404SEF and am monitoring the site again
Time to create page: 0.147 seconds
