Solved Insert formatted text, like tables or lists
10 years 8 months ago #173533 by holgerbusch
My Version: 4.0.10
Hello erverbody,
I would like know if it is possible to insert text directly from a word document or an e-mail?
When I insert a list, for example, it looks like a list in die editor.
But it is complete orientated on the left side, after saving. (I send you some photos...)
Maybe here ist someone who can explain to me if it is possible to post formatted text at all?
Thanks from Germany.
10 years 8 months ago #173534 by 9themestore
Can you post your site url here? I'll check and suggest a good solution for you.
Regrads,
10 years 8 months ago #173538 by holgerbusch
Hey. Site: www.forms.busch-dl.de
Login guest/guest
10 years 8 months ago #173539 by 9themestore
You should insert your data with correct format. Open the template.css file in the protostar joomla template and paste bellow CSS rules to the bottom of file.
#Kunena .kmsgtext table { border: 1px solid #ccc; border-spacing: 0; border-collapse: collapse; margin-top: 20px; margin-bottom: 20px; } #Kunena .kmsgtext table th { background-color: #f0f0f0; border: 1px solid #ccc; padding: 5px 10px; } #Kunena .kmsgtext table td { border: 1px solid #ccc; padding: 5px 10px; }
Save and reload your site.
