Solved update kunena component from 3.0.7 to 4.0.10
10 years 8 months ago #173484 by morris-the-best
I installed the 3.0.7 version of Kunena (forum). I would upgrade to version 4.0.10 which is the latest version. I can not find and download the update.
I can tell you exactly where I can download?
Help me please.
Best Regards
10 years 8 months ago #173487 by 810
You can update it on the backend - extensions - manage - update
Or you can download the package on the download page.
10 years 8 months ago #173489 by morris-the-best
I can not download the update from my backend.
Can you give me the exact link update this on the download page?
I looked in the download page but could not find the upgrade from 3.0.7 to 4.0.10
Best Regards
10 years 8 months ago #173490 by rich
There is no update package. First create a backup then install kunena 4.0.10 and the page will upgraded.
10 years 8 months ago #173494 by morris-the-best
Ah, OK!
I thought that there was a need to upgrade rather directly install the new version over the old (3.0.7 on 4.0.10). Did I get it right?
10 years 8 months ago #173503 by rich
Yes, you can directly install the new version over the old 3.0.7.
