- Thank you received: 5
Solved Kunena Latest module problems
1)when it supposed to show the latest topics, shows the latest posts,is there anyway to fix it ?
2) When you set in the admin the Time Period is not working, if you put 7 days for example you see in the new topics made 1-2 years ago.
Is there anyway to fox it ?
Are you planning to fix it ?
- Thank you received: 2545
Here you can see the difference (see image). Latest topic shows only the topic once. Latest posts shows all messages.1)when it supposed to show the latest topics, shows the latest posts,is there anyway to fix it ?
It uses the date of the last post, not the creation date of the topic.2) When you set in the admin the Time Period is not working, if you put 7 days for example you see in the new topics made 1-2 years ago.
I think misunderstanding created because of its name,
Is latest topic answered
not latest topic created,
correct ?
Is there a way to create latest / newest topic created list ?
Another problem,
after clicking at the end of a module like thank yous i gave or received,
takes you to an empty page.
prntscr.com/a6l7pz
