Solved How to Preload Text on Message Area
10 years 9 months ago #173108 by beyond
I would like to load default text in the message area so that my users can reply accordingly instead of entering anything that they want.
An example is something like Jomsocial support forum, which I attach the image here.
Is there anywhere I can update setting or do I need to modify source file? If so, which file do I change?
Thanks.
10 years 9 months ago #173121 by 810
components\com_kunena\template\blue_eagle\html\topic\edit.php
you can add text to the message: use the value class.
10 years 9 months ago #173146 by beyond
I am just a novice so I am not sure where I can insert the text in the file. May I know which line of code do I insert the text that I want?
