Solved attachment images missing in back-end after migration
10 years 10 months ago #172243 by betteryouthanme
i had to move the Kunena forum databases to a fresh joomla installation.
So i first imported the joomla user and group databases.
Then continued with all Kunena tables (after installing Kunena)
All works fine but in the backend attachments images are not shown:
Everything else, also the attachments in front-end, is shown.
Any ideas what went wrong and how can i fix it?
Thanks a lot
Two things fill the mind with ever new and increasing wonder and awe - the starry heavens above me and the moral law within me. Immanuel Kant
10 years 10 months ago #172246 by 810
we have fixed this bug on K4.0.6 i think, which version are you using?
10 years 10 months ago - 10 years 10 months ago #172249 by betteryouthanme
4.0.7 was installed before.
Then installed Kunena 4.0.8 on the new Joomla and imported the database from the 4.0.7 version.
Maybe i should have installed the 4.0.7 version again and then update. But i could not find it in the download section, just the latest version.
//edit:
just found 4.0.7 on GitHub .
You think this will fix the issue?
Last edit: 10 years 10 months ago by betteryouthanme.
10 years 10 months ago #172251 by 810
ok, just see it was fixed one K4.0.6
github.com/Kunena/Kunena-Forum/commit/8b...2d0f13033db6000b81e2
and when you click on the attach, has been fixed on K4.0.8
10 years 10 months ago #172253 by betteryouthanme
so it should work?
i checked my files and the components/com_kunena/admin/template/joomla25/layouts/attachment/item/default.php is the recent one. Can't be different as i installed 4.0.8 freshly. Just the database imports are from 4.0.7 version.
10 years 10 months ago #172255 by rich
You write only, that you have imported the database. Have you also imported the complete content from media/kunena?
