Solved How to limit topic content from public?
10 years 10 months ago #171819 by bettalk88
I wanted to hide or unable public to view topic content in my forum. I've been looking and doing some trial and error with the backend. Tried following kunena setup for categories and access. It ended up hiding everything of the categories from public. Help pls. :( :( :(
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : jsn_mico_free | author: JoomlaShine.com | version: 2.0.3 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.6 | creationdate: 2015-09-28
Kunena version detailed: Kunena 4.0.6 | 2015-09-28 [ Pielungo ]
Plugins: None
10 years 10 months ago - 10 years 10 months ago #171820 by rich
With a single topic it's not possible. You can create a own category only for registered users.
Last edit: 10 years 10 months ago by rich.
10 years 10 months ago #171826 by 810
or set the configuration option.
backend - kunena - configuration - security - Registered Users Only = Yes
10 years 10 months ago - 10 years 10 months ago #171832 by bettalk88
rich wrote: With a single topic it's not possible. You can create a own category only for registered users.
Not a single topic but all the topic inside categories. Your solution will only limit access of the categories to the public. What I mean is the post and topic inside categories. For example, topic How To Limit Topic Content From Public? I want to hide this content to the public.
Last edit: 10 years 10 months ago by bettalk88.
10 years 10 months ago #171833 by bettalk88
810 wrote: or set the configuration option.
Will only hide everything from Public. The worse happened when I chose this option, if I try to view at public the first search would be ok everything such as main forum and categories will be visible to public. However,after a click on anything and then when I refresh the forum as public everything is hidden. I wanted to attract members, hiding everything can backfire.
Time to create page: 0.147 seconds
