Solved in config.xml a filter="raw" - Dont works
in template config.xml i am trying to create a simple Joomla textarea field ( docs.joomla.org/Textarea_form_field_type ) with filter="raw" - but when i try to save parameter in adminside template manager, it dont saves.
i mean this simple parameter:
thank you so much,
Lorenco
but, i dont understand .. you mean it dont works?
for example, when i add in "root/components/com_kunena/template/blue_eagle/config.xml" this field:
and in "template manager" when i try to put simple HTML
after saving, the result is same - it saves only as a text: Heading, not as HTML ....
but i want HTML, i want to call it frontand template view ....
how to do that?
thank you so much,
Lorenco
thank you so much,
Lorenco
