Solved Migrating Kunena data to new location AFTER users have already been migrated
- intouchweb
I am updating/migrating a large site with hundreds of users over to a new server (upgrading from Joomla 2.5 to Joomla 3) - both sites have Kunena 4.07 installed. I migrated the users across first using J2XML and have also migrated and integrated membership data with another component etc. I now wish to migrate the forum over WITHOUT impacting the existing user data. I migrated all the jos_kunena tables over, which brought over topics and categories etc but the USER ID's have not synchronised correctly , so topics are now assigned to incorrect users. There are also permissions errors viewing the topics. I have searched everywhere for step by step manual instructions to migrate the latest Kunena across to a new location but there seems to be very little info available. I believe the problem is that I need to migrate the tables that hold user ACL information but I am unsure which tables are required and whether this will impact the existing user and membership setup that is now working Ok. Can someone advise exactly what user tables from Joomla 2.5 Kunena 4.07 need to be migrated over to synchronise the users please, or other options?
- Thank you received: 2545
*_usergroups
*_users
*_user_notes
*_user_profiles
*_user_usergroup_map
and all Kunena tables.
Go after import to "Extensions -> Manage -> Database" and click the Fix button.
- intouchweb
I have J2XML installed on both websites, but would like to know the process involved.
Any help out there would be greatly appreciated.
How, then, do I migrate the Kunena tables from one website to another?
I tried going into phpmyadmin and exporting those K tables, but am sure I did something wrong because that's when everything started breaking.
Both sites have Joomla 3.4.8 and Kunena 4.0.9. Is the migration process as simple as using phpmyadmin or am I missing something?
And if I've already grabbled the user information with J2XML, theoretically I would only have to migrate the K tables. Am I close?
Thank you again for any help that's out there. I'm pretty sure I did something incorrectly last night when exporting Kunena tables.
2) Import it in the new database
3) Check the prefix from the tables. If you have done a new joomla install, then you need to change the prefix from the kunena tables.
Also check that the users have the same id's as the old database
