Solved IP Address Tracking feature
10 years 11 months ago #170906 by Nikiniko
The IP Address Tracking feature is giving only the IP of the member.
Is it possible to make it more acvanced or is there an addon / extension,
so it will automaticaly points and track possible clones with the same IPs used in the past?
In big forums clones are big problem.
Thank you
10 years 11 months ago #170909 by 810
Replied by 810 on topic IP Address Tracking feature
if you go to the backend -kunena - users - select a user, then on the last tab you can see al users on the same ip.
10 years 11 months ago #170919 by sozzled
Replied by sozzled on topic IP Address Tracking feature
810 wrote: if you go to the backend -kunena - users - select a user, then on the last tab you can see al users on the same ip.
I would like to correct a small detail in the reply. If someone—a forum moderator—edits a message, you will also see the editors' usernames in that list of IP addresses.
10 years 11 months ago #170987 by Nikiniko
Thank you both i found it,
is there any other more accurate method to use?
10 years 11 months ago #170989 by 810
not at them moment. we want to change it, but we need to fix other things first
10 years 11 months ago - 10 years 11 months ago #170990 by sozzled
Nikiniko wrote: Is there any other more accurate method to use?
It is almost impossible to rely on IP addresses as sole determinant in website security. Putting this another way, because it's possible for people to utilise fast flux DNS hosting or spoof their IP addresses in other ways, websites can be targeted without people being able to determine the source of the attack.
The features in Kunena are not foolproof but they're reasonably adequate to dealing with common nuisances , for example, people who join a website under adifferent pseudonyms from the same IP address.
You have asked about IP address tracking and I shall confine my responses to that issue. You have asked if there are more accurate methods to use and I responded to that question. There are, however, other ways to deal with problem users.
810 wrote: We want to change it ...
I'm not sure what "it" is but I assume "it" is this: github.com/Kunena/Kunena-Forum/issues/2542
Last edit: 10 years 11 months ago by sozzled.
