- Thank you received: 5
Solved IP Address Tracking feature
Is it possible to make it more acvanced or is there an addon / extension,
so it will automaticaly points and track possible clones with the same IPs used in the past?
In big forums clones are big problem.
Thank you
I would like to correct a small detail in the reply. If someone—a forum moderator—edits a message, you will also see the editors' usernames in that list of IP addresses.810 wrote: if you go to the backend -kunena - users - select a user, then on the last tab you can see al users on the same ip.
is there any other more accurate method to use?
It is almost impossible to rely on IP addresses as sole determinant in website security. Putting this another way, because it's possible for people to utilise fast flux DNS hosting or spoof their IP addresses in other ways, websites can be targeted without people being able to determine the source of the attack.Nikiniko wrote: Is there any other more accurate method to use?
The features in Kunena are not foolproof but they're reasonably adequate to dealing with common nuisances , for example, people who join a website under adifferent pseudonyms from the same IP address.
You have asked about IP address tracking and I shall confine my responses to that issue. You have asked if there are more accurate methods to use and I responded to that question. There are, however, other ways to deal with problem users.
I'm not sure what "it" is but I assume "it" is this: github.com/Kunena/Kunena-Forum/issues/2542810 wrote: We want to change it ...
