Solved Settings for Kunena and Discuss re guest comments
I'm new to Kunena and Discuss. Joomla, too, for that matter. My site is not live. I installed Kunena, and it tested fine. Then I added Discuss.
I see the setting for the default category for the comments. Is there a way to specify for each article into which category the comments will go? I couldn't find that, so I made a new Kunena category for comments, and that category is the Discuss default. If I can't specify for each article, my moderators and I will just have to move the created topics to the correct category.
Second question: I want only registered users to be able to post or reply in the regular Kunena forums, but for guests to be able to comment on articles. Is this possible? What settings do I need to change?
I gave that open forum pubic accessibility. In my Kunena configuration I have "Allow Guests to Post/Write" on Yes. Right now only registered users can post comments. A guest user sees the other comments, but not the text-box and submit button.
2) No, if the guests is allowed to reply on the topic, he can also reply on comment. Not only on comment.
You need to do 2 things:
1: Kunena configuration I have "Allow Guests to Post/Write" on Yes
2: On edit category, you need to select also guests on the permissions
It is unfortunate that there is no documentation to explain how to use the Kunena Discuss plugin. The "best" that I can find for you are two general topics:dsibilant wrote: Is there a way to specify for each article into which category the comments will go?
- A Kunena Discuss workshop: How to allow my users to comment on my Joomla articles in my forum ; and
- Kunena Discuss "quick and dirty" instructions for use .
There are a couple of things you need to do before guests can post on your forum. First of all, as 810 has mentioned, you need to modify the forum category permissions for the categories where the comments are collected to give Guest the ability to reply to topics. Secondly, and most importantly, you need to disable Joomla caching; if caching is enabled guests cannot use the Kunena Discuss plugin to comment on your articles .dsibilant wrote: Second question: I want only registered users to be able to post or reply in the regular Kunena forums, but for guests to be able to comment on articles. Is this possible? What settings do I need to change?
However, as 810 has already written, if visitors can use the form generated by Kunena Discuss plugin (when they view the articles/blog) they can also post replies to other topics (in the same category/categories) where they have permissions.
