Solved Who Is Online and online members problem
10 years 11 months ago - 10 years 11 months ago #170876 by Nikiniko
I searched and the only thing i found is that is joomla session problem,
but is there a way to fix / set up tip for this error ?
To show all online members online and all offlive members offline ?
Thank you
Last edit: 10 years 11 months ago by Nikiniko.
10 years 11 months ago #170880 by 810
could you add more info about your problem.
10 years 11 months ago #170903 by Nikiniko
for example,
now i am online but it shows me offline
10 years 11 months ago #170907 by 810
I think its the cache, try to disable cache on the kunena configuration
10 years 11 months ago #170986 by Nikiniko
You mean this cache
Is set to closed.
Is there any other cache that can influence this ?
10 years 11 months ago #170988 by 810
the whoisonline is showing the login within 30 min or something. You can change it on configuration - frontend: Online Users Contains change to valid session, and maybe limit the next option also to lower setting.
