Kunena 6.0.9.1 Released
The Kunena team has announce the arrival of Kunena 6.0.9.1 [K 6.0.9.1] which is now available for download as a native Joomla extension for J! 4.2.x. This version addresses most of the issues that were discovered in K 6.0 and issues discovered during the development stages of K 6.0.
Solved Sticky Icons missing and emo displayed instead after upgrade to K 4.0.7
7 years 4 months ago #1 by nemmar
The Blue Eagle default push-pin Sticky Icons are missing in the forum topics and instead "emo" text is displayed after I upgraded to K 4.0.7. Here is an online example:
www.nemmar.org/forum/sticky-topics
Can you tell me what might be causing this and how to fix it?
Thanks.
Here is my Kunena Config Report:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 512M | Max file upload: 24M
Joomla default template details : JoostrapBase-v3-4 | author: Joostrap | version: 3.4 | creationdate: 29 July 2014
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.7 | creationdate: 2015-11-16
Kunena version detailed: Kunena 4.0.7 | 2015-11-16 [ Albareto ]
Plugins: Search - Kunena Search 3.1.1 | Content - Kunena Discuss 3.1.1
Modules: Kunena Latest 3.1.1 | Kunena Stats 3.1.1 | Kunena Login 3.1.1 | Kunena Search 3.1.1
7 years 4 months ago #2 by 810
7 years 4 months ago #3 by nemmar
810 wrote: here is the fix: github.com/Kunena/Kunena-Forum/pull/3536/files
Thanks for that info.
Since it's a minor bug in Kunena, rather than make a core file edit, do you think the next version of Kunena will have a fix for this?
That way I will just leave the missing icons alone for now and not make a core hack and I will just wait for the next Kunena upgrade.
7 years 4 months ago #4 by 810
its safe to edit it. On the next version it will be fixed.
6 years 9 months ago #5 by nemmar
Hi 810,
I installed the new Kunena version 4.0.11 but the "emo" text is still displaying where the Sitcky Icons should display. Is this a bug the devs decided not to fix in the latest update version?
You can see it on my forum at www.nemmar.org/forum/read-first
Here is my Kunena forum config report:
htaccess: Exists | PHP environment: Max execution time: 480 seconds | Max execution memory: 512M | Max file upload: 24M
Joomla default template details : JoostrapBase-v3-5 | author: Joostrap | version: 3.5 | creationdate: 22 April 2016
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.11 | creationdate: 2016-06-05
Kunena version detailed: Kunena 4.0.11 | 2016-06-05 [ Barcelona ]
Plugins: Search - Kunena Search 3.1.2 | Content - Kunena Discuss 3.1.2
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Login 3.1.2 | Kunena Search 3.1.2
6 years 9 months ago #6 by 810
we have fixed that issue, but when still have the old legacy dir topicicons then he will load the dir, but there is a missing icon.
So a quick fix for you is to rename the media/kunena/topicicons dir to topicicons2
Then check if you have a topic_icons dir, then all icons should work again.
The following user(s) said Thank You: nemmar
Time to create page: 0.498 seconds
