Solved Crypsis custom.less file throws 404 error in Chrome Developer Tools
11 years 2 weeks ago #169999 by bluewatersailingweb
Following the suggestions in another post to get my search button back on the page layout area (it was hanging off the page), I added some code to the custom.less file for the Crypsis template in a Kunena 4.0.3 implementation.
The code changes fixed my button issue, but I started noticing an error in my Chrome Developers Tools Console:
suggestion-box:18 GET http://185.56.85.149/~bluewa66/media/kunena/cache/crypsis/css/custom.css
This error wasn't there before.
Interestingly, my css changes do show up on the site, and will change, if I change them in the custom.less file. But, when you inspect the search submission button, it shows the following as coming from kunena.css:
#kunena.layout button.btn.btn-default { line-height: 25px; }
That's the some of the code that I put in custom.less for the Crypsis template.
What gives?
11 years 2 weeks ago #170014 by 810
mhh I see he is loading the wrong dir:
should be:
components/com_kunena/templates/crypsis/css/custom.css
