Solved Image orientation on upload - K 4.06 with Crypsis
- WolfgangOWL
- Senior Member
I recently updated from K 4.05 with Blue Eagle template to 4.06 with Crypsis. I modified the upload.php to change the orientation of uploaded images with portrait orientation using the orientation tag of jpg files. This worked fine until before the update. The same modification applied after the update has no effect at all. Can anyone help me with this?
Thanks in advance,
Wolfgang
- WolfgangOWL
- Senior Member
- WolfgangOWL
- Senior Member
810 wrote: good, could you add the code, how to change it, maybe someone else can use it.
Shure I can.
This is the function which does the image rotation:
This code must be placed in function ajaxUpload above of
catch (Exception $exception)
And this must be placed in function upload above of
if (!KunenaFile::copy($file->tmp_name, $file->destination))
throw new RuntimeException(JText::_('COM_KUNENA_UPLOAD_ERROR_FILE_RIGHT_MEDIA_DIR'), 500);
