Solved Query mysql from kunena make cpu high
11 years 2 weeks ago #169981 by tienndnguyenduc
UPDATE u3gbc_kunena_users AS u
LEFT JOIN (
SELECT userid, MAX(expiration) AS banned FROM u3
Please view and recommend me how to optimize it
Kunena: 4.0.6
Kunena user total: 321848
Thankyou so much,
11 years 2 weeks ago #169982 by 810
could you add the kunena report
11 years 2 weeks ago - 11 years 2 weeks ago #170002 by tienndnguyenduc
htaccess: Missing | PHP environment: Max execution time: 600 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : domain_db | author: domain.com | version: 1.0.0 | creationdate: Unknown
Kunena default template details : domain Mainsite Forum | author: domain Team | version: 1.0.0 | creationdate: 16/10/2013
Kunena version detailed: Kunena 4.0.6 | 2015-09-28 [ Pielungo ]
Third-party components: UddeIM 3.5
Third-party SEF components: sh404sef 4.6.0.2718
Plugins: Search - Kunena Search 3.1.1
Modules: Kunena Stats 3.1.1
Last edit: 11 years 2 weeks ago by tienndnguyenduc.
11 years 2 weeks ago #170033 by tienndnguyenduc
I found that the time to "Sending data" of query is very long,
Recommend me how to fix it,
Thanks,
11 years 2 weeks ago #170039 by 810
mhh should be ok, do you have extra plugins installed, try to disable them, and enable it, until the cpu is high again.
