Solved 0 Property "protected" is not defined
11 years 1 month ago - 11 years 1 month ago #169613 by JorgeMax
Hi all! :cheer:
When I click on "Profile" Tab, kunena show my profile "like text format"... without template... :blink:
In the explorer tab I see: 0 Property "protected" is not defined :pinch:
Do you know what is the problem?
I have:
Joomla 3.4.4
Kunena 4.0.6
Thanks in advance.
Regards. ;)
Last edit: 11 years 1 month ago by JorgeMax.
11 years 1 month ago #169614 by 810
Looks like a file isn't copied when you did a update from K3 to K4.
Try uninstall, then install again. Data will stay there.
The following user(s) said Thank You: JorgeMax
11 years 1 month ago - 11 years 1 month ago #169615 by JorgeMax
Thanks 810! :cheer:
I did it. Uninstall Kunena and install again.
No changes. Continue with this error... :(
Seems a problem with Blue Eagle template, because I have changed Crypsis as default template and profile is shown correctly...
11 years 1 month ago #169616 by 810
could you add the kunena report:
backend -kunena - tools - report
11 years 1 month ago - 11 years 1 month ago #169618 by JorgeMax
Hi again 810! :cheer:
Here is:
11 years 1 month ago #169620 by 810
ok try uninstall, check that administrator/components/com_kunena and components/com_kunena is deleted on your ftp. Then install again.
If still not working enable kunena debug on configuration. And check if there is a other error message
