- Thank you received: 2
Solved media folder (icons) overrides
- afterburner
- Senior Member
10 years 6 months ago #169398
by afterburner
media folder (icons) overrides was created by afterburner
hi !
it's possible to creat override folder for kunena ?
i want to replace media > kunena > icons adn add custom icons.
thx
thx
10 years 6 months ago #169403
by 810
Replied by 810 on topic media folder (icons) overrides
- afterburner
- Senior Member
10 years 6 months ago #169404
by afterburner
Replied by afterburner on topic media folder (icons) overrides
10 years 6 months ago - 10 years 6 months ago #169406
by 810
In K 4.0, Blue Eagle based
• /components/com_kunena/template/your_template/images/topicicons/system
• /components/com_kunena/template/your_template/images/topicicons/user
In K 4.0,HMVC
• /media/kunena/topic_icons/your_icons/system
• /media/kunena/topic_icons/your_icons/user
In K 4.0,HMVC
Last edit: 10 years 6 months ago by 810.
- afterburner
- Senior Member
10 years 6 months ago #169408
by afterburner
i know - but after updating the Kunena I have to do it again
10 years 6 months ago - 10 years 6 months ago #169409
by 810
That's why we changed it in K4.0
create a custom dir like:
You can put the system icons there, and the user icons.
Then put the xml there, to load the correct icons
system = "No selectable topic icons"
user = "Topic icons"
See:
www.kunena.org/forum/kunena-4-0-support-...n-k-4-0?limitstart=0
we are working on new docs, to get it more simple todo.
See:
Time to create page: 0.219 seconds
