- Thank you received: 2
Solved media folder (icons) overrides
- afterburner
- Senior Member
it's possible to creat override folder for kunena ?
i want to replace media > kunena > icons adn add custom icons.
thx
- afterburner
- Senior Member
• /components/com_kunena/template/your_template/images/topicicons/system
• /components/com_kunena/template/your_template/images/topicicons/user
In K 4.0,HMVC
• /media/kunena/topic_icons/your_icons/system
• /media/kunena/topic_icons/your_icons/user
- afterburner
- Senior Member
create a custom dir like:
You can put the system icons there, and the user icons.
Then put the xml there, to load the correct icons
system = "No selectable topic icons"
user = "Topic icons"
See:
www.kunena.org/forum/kunena-4-0-support-...n-k-4-0?limitstart=0
we are working on new docs, to get it more simple todo.
