Solved How to fix editor message window size, rezising / overlay issues?
11 years 1 month ago #169275 by 8b34b558ec1e411ed46e893b
Hello everyone,
I have a question that is troubling me for a longer time since I switched my Kunena template to Crypsis.
When I select "new post" the message section in the editor just shows one line, but can be resized but I can also resize it in the width, and then it does not look very smart with my template.
In addition I would like to invert all the style from black on white to white on black.
I don't have much experience with CSS though, so I was not able to find it.
11 years 1 month ago #169291 by 810
then your joomla template is overriding the css.
Please check it with inspector or firebug
11 years 1 month ago #169295 by 8b34b558ec1e411ed46e893b
Hello 810, I have Firebug installed but I am not sure where to check if this override happens.
11 years 1 month ago #169297 by 810
right click on the textarea, then you will see on the right, some variables, 1 of them are wrong
11 years 1 month ago - 11 years 1 month ago #169302 by 810
try:
#kbbcode-message { height: auto !important; }
Last edit: 11 years 1 month ago by 810.
Time to create page: 0.145 seconds
