Solved Topic Titles Preview for Guest
I have a question: I have blocked reading access on forum for guest, but I would like them to view just the titles of the topics without being able to enter them and read.
Is it this possible some way?
I need it mostly to show on the homepage the latest discussions in a module
Thank You very much
"There are no categories in this section!" with "You have to login to see categories in this section"
- Thank you received: 196
No answer for your first question, but you can change the text by making a language override.
This is known as a "teaser" .Ivan88 wrote: I have a question: I have blocked reading access on forum for guest, but I would like them to view just the titles of the topics without being able to enter them and read.
1) This can be done, by rewriting the template. There is no settings to have that behavior.
but like Sozzled said, you can use the teaser feature, that will display the first message, and hide the message on the other replies.
2) Yes, see Pinkeltje reply. You must use joomla language override.
