Solved Templates
- Oscarfishlover
- Premium Member
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
For everyone else's information, the site template here is a J! 2.5 template—it will not work on the latest J! 3.4 websites. This also means that people will not be able to use K 5.0 if they use J! 2.5 also.810 wrote: This joomla is from rockettheme - kirigami.
This template support also J3.4 see: www.rockettheme.com/joomla/templates/kirigami
I was talking about support for K 4.0—Crypsis, in particular—and future support for K 5.0 and whether the template at this website would work with either of these things. I have no idea what your unnecessary response was about.810 wrote: Please ignore Michael's reply.
Is this a question about Kunena version 4.0? If this is a question about Kunena 4.0 then please answer this question: does the Rockettheme Kirigami template for Joomla work with K 4.0 Crypsis without any changes? Yes or no?
If the answer is that K 4.0 Crypsis does work with Kirigami, why is Crypsis not used here on this website? If the answer is that there is nothing preventing K 4.0 Crypsis being used with Kirigami then, by all means, you can ignore my earlier reply to this topic.
If, on the other hand, there are other matters involving the Kirigami template that oscarfishlover should know then I think you should be frank about informing him what else he may need to be aware of. That was the purpose of my earlier reply.
- harmlessdrudge
- Junior Member
- Thank you received: 2
Or, That's not the case, or something similar.
