Solved Image dragging from web problem
11 years 2 months ago #168577 by taraktalluri
when i drag the the image url into new kunena topic... it show only url... how to change it to image format
11 years 2 months ago #168579 by xillibit
Can-you make please a screenshot like we can see the issue ?
11 years 2 months ago - 11 years 2 months ago #168581 by taraktalluri
please check this screenshot when i dragging appear like this, not showing image
i.imgur.com/lOorjLS.png
Last edit: 11 years 2 months ago by taraktalluri.
11 years 2 months ago #168595 by rich
Use the image code and it should work.
[img]http://i.imgur.com/lOorjLS.png[/img]
11 years 2 months ago - 11 years 2 months ago #168596 by taraktalluri
but bydefault is showing url when i drag image from other sources is it possible to add image without using [img /img]
11 years 2 months ago - 11 years 2 months ago #168617 by sozzled
taraktalluri wrote: ... is it possible to add image without using ["img" BBcode ]
The short answer to this question is no.
I have a much longer answer (if I had an hour to write it) but the short answer to your question is no.
Last edit: 11 years 2 months ago by sozzled.
The following user(s) said Thank You: taraktalluri
