Solved The Forum Tab disappears in Edit mode
11 years 1 month ago #168129 by Yxos
We run Joomla 3.4 with Kunena 4.0.5 with CB 2.0.10.
On our "old" Joomla 2.5 site with Kunena 3.0.8 & CB 1.9.1 it used to work like this:
In Display mode, the profile would have a "Forum" tab showing the Latest posts
In Edit Mode, the the profile showed the Forum Signature, so that you could change it.
In our new Kunena 4.0.5 (on Joomla 3) The Forum tab is simply missing, when in Edit mode, and so, it is not possible for our users to change their forum singature.
Is there a setting in the new Kunena that I am not aware of?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : redCOMPONENT | author: redCOMPONENT | version: 1.4.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.5 | creationdate: 2015-08-17
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Third-party components: CommunityBuilder 2.0.10 | UddeIM 3.7
Plugins: None
Modules: Kunena Latest 3.1.1
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
11 years 1 month ago #168131 by xillibit
In your profile you should see the same tabs than Kunena 3.0.8, can-you look into development console of your browser if you can see javascript errors ?
11 years 1 month ago - 11 years 1 month ago #168132 by Yxos
I am not familiar with the development console of the browser.
However, the problem is general. All users have the problem.
I forgot to mention a diffence in the backend for the CB field Management. On the "old" site 3 fields appear with Tab "Forum"
For some reason there are NO fields in the new site for CB field Management, related to tab "Forum".
This could explain why the "Forum" tab is not shown in Edit Mode; there are no fields to display in that Tab.
So, the question is: Why are they not in the new site?
Even more important; how to get them there?
It is not possible to add a new Field with the type "Forumsettings" which makes me believe that they probably appeared during installation of Kunena.
...or, they should have been.
Is there a point during the Kunena installation process, where these 3 CB fields are inserted?
Can it be replicated manually?
(Am I on the right track?)
Last edit: 11 years 1 month ago by Yxos.
11 years 3 weeks ago #168353 by Yxos
I was told by the people we paid for to upgrade our site from Joomla 2.5 to 3.0, that the above is not possible at all!
Apparently CB does not provide an option to maintain Kunena signature and other fields in the profile maintenance.
I find that hard to believe, so I would like to hear if Kunena people share that opinion?
10 years 3 months ago #175849 by jplamp
Sorry to resurrect an old topic, but I am having the same problem. I can't figure out how to get it so that users can edit their forum signatures - ANYWHERE. Specifically, I want the ability to edit the forum signature in the CB profile, like we could in earlier versions of CB and Kunena. Any help would be appreciated.
Here's my current configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 800M | Max file upload: 300M
Joomla default template details : beez3 | author: Angie Radtke | version: 3.1.0 | creationdate: 25 November 2009
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.11 | creationdate: 2016-06-05
Kunena version detailed: Kunena 4.0.11 | 2016-06-05 [ Barcelona ]
Third-party components: CommunityBuilder 2.0.14 | UddeIM 3.8
Plugins: Search - Kunena Search 3.1.2
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Login 3.1.2 | Kunena Search 3.1.2
Kunena 4.0.11, Joomla 3.5.1, CB 2.0.14, DOCman 2.1.5, uddeIM 3.8
10 years 3 months ago #175852 by 810
Create a new Field on CB "signatures". Then connect it to kunena by going to
cb - plugin - cb forums - forum - select Kunena 3.x - Signature = cb_signatures
Then save it.
The following user(s) said Thank You: jplamp
Time to create page: 0.297 seconds
