Solved Problem with topic display in Crypsis template
11 years 3 months ago #167997 by carlat2
When I activate the Cyrpsis template the text box is usually large.
Any ideas why?
11 years 3 months ago #167998 by 810
its taking the css from the template. So one css line is wrong. I need to see this behavior, to solve this issue for you.
11 years 3 months ago #168000 by carlat2
You can see it online here:
tresjolie.com.ar/forotj
test user: sample3/sample3
thanks very much!
11 years 3 months ago - 11 years 3 months ago #168001 by 810
1) Kunena Template manager
2) Select crypsis - edit less
3) Select custom.less
4) Paste:
.kmsg { height: auto !important; margin: 20px 0; word-wrap: break-word; }
5) Click on save
6) clean cache.
Then it should be working.
if not add this on the joomla template css:
.layout#kunena .kmsg { height: auto; margin: 20px 0; word-wrap: break-word; }
ps I think if you disable the optimize plugin, the othere issues are also solved
Last edit: 11 years 3 months ago by 810.
