Solved W3 testing failure - "follow"
11 years 3 months ago #167886 by bins
W3 testing gets me several errors around 'follow' e.g.
Error: Bad value follow for attribute rel on element a: The string follow is not a registered keyword.
From line 931, column 4; to line 931, column 76
ject">↩ <a href="/forum/introductions/12-point-of-need-training#16" rel="follow">Point
I have just upgraded to 4.0.5 and have 14 related issues/errors identified
11 years 3 months ago #168011 by xillibit
Thanks for reporting that, it was intented to put a rel="follow" to avoid duplicate URLs.
11 years 3 months ago #168021 by bins
Replied by bins on topic W3 testing failure - "follow"
Whilst it probably isn't a real 'operational' issue, is there away to may things compliant?
11 years 3 months ago #168037 by xillibit
We need to change most of the function which generate URLs to remove the rel="follow", i need to do some check to avoid duplicate URL if this change is done
11 years 3 months ago #168039 by bins
OK, thanks
