Solved Kunena 4x RTL support ?
dose Kunena 4x RTL support ?
dose the new Blue Eagle template support RTL ?
is there a way so support RTL ?
www.catalogo.co.il/index.php?option=com_...tmenu=228&Itemid=227
do i need to turn it on or something ?
add this to your default template because if you will update the forum in the future it not going to replace the original css blue eagle template file...
take a look here
www.hibukhay.co.il/index.php?option=com_...tmenu=228&Itemid=227
could you test this fix:
github.com/Kunena/Kunena-Forum/pull/3360/files
it should load the css file now
