Solved KunenaLatest - Link issue
11 years 3 months ago #167671 by Yxos
We use the Forum Latest module on the front page. We also did this back on Joomla 2.5 with Kunena 3.
Each KunenaLatest reference contains a link that leads to the Topic in question.
On the old site, the link was always suffixed with "/unread" meaning that each user would be directed to his latest unread post for the topic.
On our new site, the /unread suffix is not used. I tried to look for a parameter in the backend but without finding any.
Has the /unread parameter disapperad with KunenaLatest 4?
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
11 years 3 months ago #167675 by 810
Replied by 810 on topic KunenaLatest - Link issue
we have fixed that.
Now you have only unread, when you login. Because before guests has unread to, that's wrong.
11 years 3 months ago - 11 years 3 months ago #167720 by Yxos
Replied by Yxos on topic KunenaLatest - Link issue
Sounds good - Except... It doesn't work for us.
When signed in, I get a link like xxxxx.com/forum/andet/842-nd-news?start=696#14256
Exactly the same as when not logged in.
Do you have any idea why?
We use Kunena 4.0.3 with CB 2.0.10 but that should not mean any difference for KunenaLatest, I think...
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : redCOMPONENT | author: redCOMPONENT | version: 1.4.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.3 | creationdate: 2015-06-29
Kunena version detailed: Kunena 4.0.3 | 2015-06-29 [ Possagno ]
Third-party components: CommunityBuilder 2.0.10 | UddeIM 3.7
Plugins: None
Modules: Kunena Latest 3.1.1
Last edit: 11 years 3 months ago by Yxos.
11 years 3 months ago #167730 by 810
14256 is the first message id from the topic, so that's why you see it. But when you have unread it should be like 14257 for login user and unread.
11 years 3 months ago - 11 years 3 months ago #167731 by Yxos
Maybe I don't quite understand how /unread works.
When I right-click the link in FrontEnd, and select "Copy link" and then paste in here in this post, does that mean that the "/unread" already made its tricks, and ensured that I got the last unread post in the link; which in my case is 14256?
I find that hard to believe because when looking at the backup of our Joomla! 2.5 site, when it was still running Kunena 3.0.8, the link would appear like: xxxxxx.com/oldj25/forum/andet/842-nd-news/unread , no matter if I am logged in or not, so that confirms your first statement;
But you're the expert, so I am open for any ideas or suggestions you might have.
I can offer you to have a look at our site with Admin rights if you want?
11 years 3 months ago #168048 by Yxos
Does anybody else miss the /unread in the hyperlink from Latest-Module ?
Time to create page: 0.154 seconds
