- Thank you received: 36
Solved IP Address Tracking Requirements?
it always shows my server IP address instead of user IP.
Does anybody knows where can take a look in order to fix this issue?
Joomla 3.4.3
Kunena 4.0.3
PHP 5.4.43
MySQL 5.6.23
Apache 2.4.12
Thanks in advance,
Can you see the ip in the database?
I have CSF installed in my server810 wrote: can't reproduce this, are u using extra security extensions, like akeeba pro, or sh404sef with extra security enabled?
Cpanel 11.50 (Build27)
Yes, The same IP address is saved for all users.810 wrote: Can you see the ip in the database?
Joomla Backed -> Components -> Kunena Forum -> User manager -> Click in a user -> IP -> There are other users using the same IP address (A lot)
That is because this problem occurs only to me, in my actual server810 wrote: can't reproduce this
If I move my website to a new server the problem disappear
So, I am just wondering if someone knows where I can take a look (I mean server side, not in kunena)
#Solved
