Kunena 6.1.0 Released
The Kunena team has announce the arrival of Kunena 6.1.0 [K 6.1.0] which is now available for download as a native Joomla extension for J! 4.3.x & J! 4.2.x. This version addresses most of the issues that were discovered in K 6.0 and issues discovered during the development stages of K 6.0
Solved Kunena menu tabs not displaying at top of a forum.
7 years 10 months ago - 7 years 10 months ago #1 by nemmar
One of my Kunena forums does not display the menu tabs at the top of the forum home page. I have attached a screenshot of the tabs I'm referring to from another forum.
Can you tell me how to enable those menu tabs to display?
Thanks.
Here is my config report:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 512M | Max file upload: 24M
Joomla default template details : JoostrapBase-v3-4 | author: Joostrap | version: 3.4 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.3 | creationdate: 2015-06-29
Kunena version detailed: Kunena 4.0.3 | 2015-06-29 [ Possagno ]
Plugins: Search - Kunena Search 3.1.0 | Content - Kunena Discuss 3.1.0
Modules: Kunena Latest 3.1.1 | Kunena Stats 3.1.0 | Kunena Login 3.1.0 | Kunena Search 3.1.0
Last edit: 7 years 10 months ago by nemmar. Reason: Attach screenshot.
7 years 10 months ago #2 by rich
You use in your main menu a wrong menu item.
Links of other menus, which are linked to the forum, must be Menu Item Type = "Menu Item Alias"
www.kunena.org/docs/Kunena_menu_issues
Time to create page: 0.294 seconds
