Solved Registration not working
11 years 4 months ago #167223 by websiteprojects
Hi
I have added the component and when a user creates an account it works successfully and the activation email is received. When the account is then activated and the user tries to login they get the error message
Warning
Username and password do not match or you do not have an account yet.
The account username and password are correct and the user is registered in the joomla User Manager.
Could you please advise what the issue is here?
Here is a link to where I am having the issue:-
country-counter.com/index.php/Forum.html
11 years 4 months ago #167228 by 810
Replied by 810 on topic Registration not working
do you see the user in the kunena user manager in the backend.
11 years 3 months ago - 11 years 3 months ago #168022 by websiteprojects
yes - the user is showing in the joomla User Manager and in the Kunena User Manager. If you test using the link provided above you will see that you create an account but you are then not able to login.
Please test and advise what the issue is?
Felicity
Last edit: 11 years 3 months ago by websiteprojects.
11 years 3 months ago #168024 by 810
then the user registration Is set wrong.
Please add kunena report.
We use the joomla registration.
What do you see on the kunena user manager. Is all enabled and activated. or all users blocked?
11 years 3 months ago #168025 by websiteprojects
what is Kunena report?
The user status is "active"- see attached
11 years 3 months ago #168026 by websiteprojects
and this is the screen grab from Joomla User Manager...
