Solved Bad Image Quality
11 years 4 months ago #166811 by Remixful
Bad Image Quality was created by Remixful
I've tried messing around with the "Avatars" tab in config but it doesn't seem to change anything, no matter what image I upload. For some reason my image looks fine on another kunena forum but not mine.
Anyone know what settings I could use? Or perhaps I have to go into kunena's files or something...
Please help! Thanks!
My website:
11 years 4 months ago #166813 by 810
Replied by 810 on topic Bad Image Quality
try the settings on uploads tab, "Image Quality for JPG Resizing" set to 100%
11 years 4 months ago - 11 years 4 months ago #166854 by Remixful
Replied by Remixful on topic Bad Image Quality
810 wrote: try the settings on uploads tab, "Image Quality for JPG Resizing" set to 100%
Still the same quality. :( Also my images are pngs.
EDIT: It also seems like this forum does it as well...
Last edit: 11 years 4 months ago by Remixful.
11 years 4 months ago #166894 by Remixful
So nobody can fix this? Alright! Thanks. I'll just stick to bad quality images.
11 years 4 months ago #166896 by 810
you can try the switching "Avatar Resize Method" setting. then upload the image again, after test each setting.
11 years 4 months ago - 11 years 4 months ago #166913 by Remixful
The image looks the same regardless of which "Avatar Resize Method" I use. I'm assuming the website that doesn't mess up my avatar edited the uploading/resizing code. :'(
