- Thank you received: 2538
Solved Category Icon in kunena 4 [SOLVED]
denisp wrote: yes, but this tutorial is about old versions of Kunena.
I don't see anything about the class of the new icon.
is this still valid?
thnak you
Paths for Kunena 4.0 added.
www.kunena.org/docs/Category_icons
Nice try, rich, but this tutorial now reads even worse than before.rich wrote:
thnak you
At the beginning of the Wiki article , it states (in the definition), "Category icons have been a feature of Kunena from the very beginning. These icons serve as a two-state indicator on category indexes to show ..."
The article then goes on to describe how to replace the "default" images or add new .GIF images that operate with the Blue Eagle template. The article then mentions that the information has been updated for K 4.0 ... and that's where I have a problem with your update.
The information in the Wiki does not apply to K 4.0 as far as the Crypsis template is concerned. This vital piece of information is missing from your changes, rich.
This is what rich added:
That is not true. If you change these files (and only these files) you will not change the effect if you use the Crypsis template.Changing category icons in K 4.0 is simply a matter of replacing any or all of the files referred to below:
../components/com_kunena/template/blue_eagle/images/icons/folder.png
../components/com_kunena/template/blue_eagle/images/icons/folder_nonew.png
../components/com_kunena/template/blue_eagle/images/icons/folder_sm.png
../components/com_kunena/template/blue_eagle/images/icons/folder_nonew_sm.png
Unfortunately, because only the Kunena forum moderators have access to the Wiki, we cannot amend the user documentation or suggest changes to improve it.
The subject is "Category icon in Kunena 4". The topic is located in the K 4.0 General Questions category. There is no mention in the subject that the discussion is confined only to the Blue Eagle template. In fact, your colleague 810 has allowed the discussion to extend to all of K 4.0 (which therefore extends to the Crypsis template as well).
For these reasons, and for others too numerous to write here, I disagree with your assessment of the situation. I reaffirm my earlier position. Your recent changes in the Wiki do not make it clear that the information does not apply to all forms of K 4.0. Further, the Wiki provides no information about category icons and how they are controlled by the K 4.0 Category Manager. Sorry for disputing the matter but that's my assessment.
@denisp: I have yet to tested 810's advice. I will let everyone know what I discover.
applehc wrote: Hello denisp,
Is very simple:
Nooooo, Page Not Found
Any new documentation on category-icon configuration in either of the 2 default Kunena templates? Perhaps somebody can copy-pasta the old stuff?
