Solved You have an error in your SQL syntax; line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages
11 years 5 months ago #166168 by Kotsolis
I have this error and I think it exists since version 3.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-08-2014' at line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages29-08-2014
My configuration.
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : whiteboard | author: Opensource | version: 2.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.0-BETA1 | creationdate: 2015-04-12
Kunena version detailed: Kunena 4.0.0-BETA1 | 2015-04-12 [ Blue Dawn ]
Third-party components: Jomsocial 3.2.1.4
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Search 3.0.1
How can I fix this error?
11 years 5 months ago #166170 by 810
You have still Kunena 4.0.0-BETA1.
First update, then we will help you.
11 years 3 months ago #167614 by Kotsolis
Now I have v4.0.3.
Same error. Please tell me what to do.
htaccess: Exists | PHP environment: Max execution time: 72000 seconds | Max execution memory: 4096M | Max file upload: 1024M
Kunena version detailed: Kunena 4.0.3 | 2015-06-29 [ Possagno ]
11 years 3 months ago #167617 by sozzled
You may have updated the component to K 4.0.3 but you are still using the beta version of the template which is probably also responsible for your other unsolved problems. Perhaps, when you update to K 4.0.3 Blue Eagle we may be able to help you.
Your configuration report also shows that you are using (or you have installed) JomSocial - My Kunena Forum Menu 2.0.3, JomSocial - My Kunena Forum Posts 2.0.3 and JomSocial - Kunena Groups 2.0.3. These plugins are not supported and they do not work with K 4.0.
When you attend to thes two areas (update to K 4.0.3 Blue Eagle template and uninstall the unsupported plugins) you may find that the error message will disappear. If you do not try these ideas first then I do not think we can help you.
Time to create page: 0.169 seconds
