Solved Gap missing when using quote
11 years 5 months ago #166147 by Kotsolis
When Using a quote in a message and there is a gap before the quote, this gap is missing when clicking Submit.
As you see in the following screenshot, when I edit the file, there is a gap. On the live site there is no gap. Please fix this.
Configuration.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-08-2014' at line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages29-08-2014
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : whiteboard | author: Opensource | version: 2.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.0-BETA1 | creationdate: 2015-04-12
Kunena version detailed: Kunena 4.0.0-BETA1 | 2015-04-12 [ Blue Dawn ]
Third-party components: Jomsocial 3.2.1.4
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Search 3.0.1
11 years 4 months ago #166563 by sozzled
This problem has been fixed inK 4.0.3
11 years 3 months ago - 11 years 3 months ago #167895 by Kotsolis
The issue has not been solved.
There is always one line break less than it should be.
Quote test. 0 line breaks above
test reply
Quote test. 1 line break above
test reply
Quote test. 2 line breaks above
test reply
Quote test. 3 line breaks above
test reply
(Look at this post. The issue remains)
Last edit: 11 years 3 months ago by Kotsolis.
