Solved [code] not working
11 years 5 months ago - 11 years 5 months ago #166074 by pascalbout
hello
I have installed jomla 3 with kunena 4 to use the Code button.
But i don't have the list with "css, diff, php" like that (like you ! )
I don't have it, i have this :
juste the [ code ] :(
It is an extension ? How can i do to have the code list please ?
Last edit: 11 years 5 months ago by pascalbout.
11 years 5 months ago #166076 by pascalbout
Replied by pascalbout on topic [code] not working
For information, if i put the "Enable Code Highlighting" to Yes, the BBCode [ code ] is not working.
If i put to No, the [ code ] is working, but without the list code.
11 years 5 months ago #166080 by rich
Replied by rich on topic [code] not working
The following user(s) said Thank You: pascalbout
11 years 5 months ago #166093 by pascalbout
hello
thank you for your help.
so i have installed this:
codeeditor.ciplogic.com/index.php/download/joomla-downloads
I have installed the recommanded HTML script :
Code Renderer HTML GeSHi
0 Configuration1 Yes No
True WYSIWYG2 Yes No
Syntax coloring3 Yes Yes
Download (recommended) Download
with this doc:
www.geoffhayward.eu/archive/the-secret-o...ax-highlighter.xhtml
and enable it in the plugin manager
but i have always the problem
i have done a mistake ?
thank you
11 years 5 months ago - 11 years 5 months ago #166110 by rich
Why you have installed this extension? Install the GeSHi Plus plugin and it should work.
www.geoffhayward.eu/downloads/Joomla-GeSHi-Plus.zip
Last edit: 11 years 5 months ago by rich.
