Kunena 7.0.8 Released
Solved When replying, instead of topic title I see the word "topic"
11 years 2 months ago #165710 by Kotsolis
This happens in all topics.
Minor bug but easy to fix, so please fix it. :)
Keep it up. Icons in the new version are awesome.
Can't wait for templates.
11 years 1 month ago #165829 by Kotsolis
Configuration report follows.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-08-2014' at line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages29-08-2014
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : whiteboard | author: Opensource | version: 2.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.0-BETA1 | creationdate: 2015-04-12
Kunena version detailed: Kunena 4.0.0-BETA1 | 2015-04-12 [ Blue Dawn ]
Third-party components: Jomsocial 3.2.1.4
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Search 3.0.1
11 years 1 month ago #165830 by 810
This will be fixed in next version K4.0.2
Time to create page: 0.260 seconds
