Solved Template: Crypsis Features
What is the display footer option in Crypsis features?
I can't see any change in the front-end...
- rss on the bottom
- Iime create/powered by
- bottom module position.
rss turned off and bottom module position not used are the reason I can't see any change.
If lime create/powered by means display/hide "Powered by Kunena Forum" it has no effect on my site even after cleaning the cache...
Supporter wrote: Thank you for such an immediate reply !
Thank you!
