Solved Can not edit profile
11 years 5 months ago #165685 by randwic
Replied by randwic on topic Can not edit profile
the update still does not allow me to be able to edit the profile
11 years 5 months ago #165686 by 810
Replied by 810 on topic Can not edit profile
I thinks its a plugin, conflict.
Disable all none joomla/kunena plugins,check if works then enable them one by one.
11 years 5 months ago #165688 by randwic
I disable Kunena plugin one by one but still nothing
11 years 5 months ago - 11 years 5 months ago #165689 by sozzled
Replied by sozzled on topic Can not edit profile
I think 810 meant to write "disable all non-Kunena plugins, one by one". In other words, he was probably trying to say that he thinks your problem is not caused by Kunena but by some other extension you are using.
I saw that you were having problems with Tapatalk. Perhaps Tapatalk is the cause of this problem, too?
I also see that your database has the wrong collation for one of your tables (_kunena_pratings). I do not know anything about this table.
Last edit: 11 years 5 months ago by sozzled.
11 years 5 months ago #165691 by randwic
I updated my database but still nothing
11 years 5 months ago - 11 years 5 months ago #165693 by 810
you should disable "none Joomla/Kunena plugins" So let default joomla and kunena plugins enabled, and disable all other plugins, also disable tapatalk
Last edit: 11 years 5 months ago by 810.
