Solved Advertising Module
I have been searching for the past few days, but I just can't get this to work.
I want to place a banner after the first post. I have seen this www.kunena.org/docs/Where_I_can_insert_advertising%3F but when I create a Module I don't see the Kunena positions.
I have looked in the Components sections, but still can't figure it out.
Any help would be appreciated.
- Thank you received: 2544
You must write the position manually in the field and then press Enter before you save.
What kind of name for the position ? For exemple
