Question captcha not working after last upgrade to 7.0.9
3 weeks 4 hours ago #235299 by ita4012
Hi.
After last kunena upgrade to 7.0.9 version, captcha to check if the user is a robot doesn't work anymore in my website.
If I enable it in Kunenca configuration (I have always set it in order to check the user until he has posted three messages), the registered user can't write a new post. That is, when he clicks on submit to post the message, after having flagged the captcha field, nothing more happens, and the new message remains not sent.
Any tips?
2 weeks 6 days ago #235301 by 9themestore
Hi @ita4012,
I believe this issue will be fixed in the next version of Kunena. However, please follow the steps below to ensure your website functions exactly as you want it to.
- Step 1: Back up the file TopicController.php in the "[root]/components/com_kunena/src/Controllers/" path.
- Step 2: Open the TopicController.php file and go to about line: 734
- Step 3: Replace below line:
if (!$captcha->checkAnswer(\null)) {
by
if (!$captcha->checkAnswer($app->getInput()->post->getString('captcha', ''))) {
Save and try to post.
Note: This is merely a temporary solution to get your website up and running again. I do not recommend modifying the Kunena core.
Kind regards,
The following user(s) said Thank You: xillibit, ita4012
2 weeks 6 days ago #235303 by xillibit
Thanks for the report and thanks for the fix, i have just added the fix :  github.com/Kunena/Kunena-Forum/commit/f4...bf0911453579188da9c1
Time to create page: 0.224 seconds
